February 12, 2024 at 5:41 am
February 12, 2024 at 7:15 am
Devendra Badgujar
Forum ModeratorHello Felipe,Â
From the above image it looks like your design in the current session uses large units. The model you are inserting might not be saved in large units so it cannot be inserted to this current session. You will need to start a new session and switch to Standard units to open that file.Â
You can insert large units models into large units session. Let me know if you have further questions on this.Â
DevendraÂ
February 12, 2024 at 1:03 pm
felipefreiredecarvalho
SubscriberHello Devendra,
Great, I found the problem here, you were right I didn't know it, thank very much for support.
February 12, 2024 at 1:21 pm
Devendra Badgujar
Forum ModeratorNo problem Felipe, happy to help!Â
DevendraÂ
- The topic ‘Insert Geometry is failing on ANSYS Discovery’ is closed to new replies.
