November 16, 2023 at 9:55 pm
Bond Wolf
SubscriberI am learning how to do thermal simulation with workbench. Because the heat in a tire is generated by the deformation of the rubber, so I want to add the heat generation rate (a function about stress and strain) as a heat source. But I didn't find a tutorial about this. Does anyone know how to do it? Maybe something about APDL?
November 17, 2023 at 8:04 am
Ashish Khemka
Forum ModeratorHi Bond,
If you know the heat generation locations at different locations then you can use the External Data module to apply heat generation on a deformed model. I am not sure on how you can do the same based on stress and strain.
How to access the ANSYS Online Help
Ashish KhemkaÂ
November 18, 2023 at 12:05 am
Bond Wolf
SubscriberThank you very much for your answer! What I'm thinking of is inserting stresses and strains as initial variables in the steady state thermal analysis, and then constructing a function about the stresses and strains via APDL commands. The function results are then added to the nodes as heat generation rate loads. Is this possible?
November 20, 2023 at 9:52 am
Ashish Khemka
Forum ModeratorHi,
I think you will need to apply heat generation on elements via BFE command.
Ashish Khemka
- The topic ‘Insert a heat generation rate function as a heat source in a thermal simulation’ is closed to new replies.
5834
