October 3, 2024 at 1:31 pm
455266651
SubscriberHello,
I am a graduate student who primarily uses Ansys FLUENT.
I would like to conduct an LES simulation.
Based on publicly available materials I found on Google (Quick Guide to Setting Up LES-type simulations, Version 1.4, May 2016), I would like to initialize my LES simulation using RANS steady-state results.
According to the reference, the following TUI command can be used for this setup:Â
/solve/initialize/init-instantaneous-velHowever, in the version of FLUENT I am using (24R1), I cannot find
init-instantaneous-vel under theÂ/solve/initialize menu.Check the related post, the new version is updated to /solve/init-turb-vel-fluctuations , but I have not yet found it.
Could you please explain how I can perform unsteady initialization in this case?
Thank you in advance for your assistance.
October 3, 2024 at 1:40 pm
Forum ModeratorCan you check you've got LES set? If you're still using a RANS model the menu's may not be available.Â
October 3, 2024 at 2:05 pm
October 3, 2024 at 2:20 pm
455266651
SubscriberThere is no such command in LES or RANS
October 3, 2024 at 2:45 pm
Forum ModeratorWhat models are on, and how well converged is the flow?
5944
1307
