August 8, 2025 at 11:21 am
BoyuZ310
SubscriberHello,When I start the solutions in LS-Run I get the error just after the initialization and the process terminates:Memory required to process keyword : 62484718Additional dynamic memory required : 21145232input of data is completedforrtl: severe (157): Program Exception - access violationImage PC Routine Line Sourcelsdyna_sp.exe 00000001420BFBF5 DETBKM 37017 dyn2.Flsdyna_sp.exe 00000001420C60D1 INITLZ 2319 dyn2.Flsdyna_sp.exe 000000014206E9AD INTIAL 256 dyn2.Flsdyna_sp.exe 0000000140BB185A OVERLY 269 dyn0.Flsdyna_sp.exe 000000013FB73C68 LSINPUT 1746 dynm.Flsdyna_sp.exe 000000013FB72F45 LSDYNA1 799 dynm.Flsdyna_sp.exe 000000013FB729B3 MAIN__ 1888 dynm.Flsdyna_sp.exe 00000001490EBD8E Unknown Unknown Unknownlsdyna_sp.exe 0000000149D96E30 Unknown Unknown Unknownkernel32.dll 000000007713652D Unknown Unknown Unknownntdll.dll 00000000775BC521 Unknown Unknown UnknownWhat does this message mean? I tried to change the precision version or the solver version to each of R6-R11, but they didn't work at all. I write to see if anyone has any idea what it might be or where i can look to figure it out.Thank you for your response in advance. -
August 11, 2025 at 5:42 pm
Pedram Samadian
Ansys EmployeeHi,
Have you tried using any MPP solvers? Please use the latest solver (R16), which can be downloaded at LS-DYNA (user=user) Download Page.
I look forward to your feedback.
Thanks,
Pedram
August 12, 2025 at 1:44 pm
BoyuZ310
SubscriberHi,
Thank you for your advice.
I have tried using solvers like, SMP simgle precision, SMP double precision and MMP. Unfortunately, they don't work since they make the same failed result. For the latest solver, I'm afraid I can't do that way cause I'm not intended to modify the computer that I use temporarily. Anyway, thank you very much. If there's any other suggestions, I would be glad to hear and try.
August 12, 2025 at 2:45 pm
Pedram Samadian
Ansys EmployeeHello,
Thanks for the feedback. With the latest solver, you don’t need to change anything on your computer, and your default solvers will remain installed. Simply save the latest solver to a location on your computer and update the solver path in the software you use to run your input deck.
The error you’re seeing appears to be related to a bug in your current solver, which may have been resolved in the latest version.
Please let me know if you have any questions.
Thanks,
Pedram
3772
1358
1173
1090
1014
