Input volumetric heat flux in CFX
    • jungsungsuk
      Hello.
      Can I input the volumetric heat flux in CFX domain?
      I want to consider heat exchanger with only one fluid, so I have to input the heat flux data from the experimental results.
      I have the total heat flux data in dimension [kW].
      I want to input the data to entire fluid domain in dimension [kW/m^3]
      Can I input the data like that? How can I?
      Thank you.
    • Surya Deb
      I am guessing you want to provide a Volumetric Heat Source and not a Surface Heat Flux.
      You can make use of Subdomain Approach in CFX. Once you create a subdomain, you can then provide your Energy Source.
      In CFX, you can also use Profiles from Tools->Initialize Profile Data.
      You can find more information in CFX documentation for both Subdomain and Profiles.
      SD
    • jungsungsuk
      Thank you for your reply.
      I have applied the Subdomain and Energy source to the domain, but in the CFD-post, its temperature didn't vary.
      I think the Energy source didn't applied normally,
      These are the settings I have inserted. I there any problem inserting the subdomain and heat source?
      Thank you in advance.
  • The topic ‘Input volumetric heat flux in CFX’ is closed to new replies.
