October 17, 2023 at 3:13 am
jeremy.stone
SubscriberI would like to run the simulation with multiple flow rates parametrically. I have setup an input parameter of the mass flow rate on the inlet, but how do I define my range of flowrates to use? Â
October 17, 2023 at 1:11 pm
Forum ModeratorWhich parametric approach did you use? Ie Fluent standalone or through Workbench?
October 17, 2023 at 1:18 pm
jeremy.stone
SubscriberÂ
I used workbench. I’m running 2020 R2 which doesn’t seem to have a parametric tab in the ribbon menu.
October 17, 2023 at 2:44 pm
Forum ModeratorOK, the parametric stuff is in Workbench. You should see a parameter box connected to the workflow, right (or double, I can't remember) click to open that up & you should see the table.Â
- The topic ‘Input parameters’ is closed to new replies.
- affinity not set
1487
1338
1171
