May 11, 2024 at 5:02 am
fang pc
SubscriberI have some problems when using shell99 element keyopt2,3, I input A B D E F matrix, and ensure that they are positive definite, but when calculating, ansys prompts an error,
*** ERROR ***Â Â Â Â Â Â Â Â Â Â Â Â Â Â CP =Â Â Â Â 9.406Â Â TIME= 10:53:01
 Input matrix of element 1 is not positive semi-definite. Check real  Â
 constant table 1.                           Âhow to solve it
Here's what I wrote about apdl/prep7
ESEL,s,elem,,    1,    1,  1600
ET,    1,99
KEYOPT,    1,2,3
R,    1, 0.10000000E+12
RMODIF,    1,2, 0.91158854E+02
RMODIF,    1,4, 0.21316282E-13
RMODIF,    1,7, 0.10000000E+11
RMODIF,    1,9, 0.26645353E-14
RMODIF,    1,12, 0.10000000E+11
RMODIF,    1,16, 0.10000000E+11
RMODIF,    1,19, 0.10000109E+11
RMODIF,    1,21, 0.10000109E+11
RMODIF,    1,22, 0.10000002E+10
RMODIF,    1,23, -0.68903426E+02
RMODIF,    1,25, 0.94291151E+02
RMODIF,    1,28, 0.99999998E+09
RMODIF,    1,30, 0.38613569E+02
RMODIF,    1,33, 0.10000000E+10
RMODIF,    1,37, 0.99999993E+09
RMODIF,    1,40, 0.99993110E+09
RMODIF,    1,42, 0.99993110E+09
RMODIF,    1,43, 0.10000000E+11
RMODIF,    1,44, 0.43756250E+02
RMODIF,    1,46, 0.52558450E+01
RMODIF,    1,49, 0.10000000E+11
RMODIF,    1,51, 0.68758909E+00
RMODIF,    1,54, 0.10000000E+11
RMODIF,    1,58, 0.10000000E+11
RMODIF,    1,61, 0.10000052E+11
RMODIF,    1,63, 0.10000052E+11
RMODIF,    1,64, 0.10000005E+10
RMODIF,    1,65, -0.19689154E+03
RMODIF,    1,67, -0.52614462E+03
RMODIF,    1,70, 0.99999994E+09
RMODIF,    1,72, -0.21546371E+03
RMODIF,    1,75, 0.10000000E+10
RMODIF,    1,79, 0.99999980E+09
RMODIF,    1,82, 0.99980311E+09
RMODIF,    1,84, 0.99980311E+09
RMODIF,    1,85, 0.10000000E+11
RMODIF,    1,86, 0.37805400E+02
RMODIF,    1,88, 0.14545551E+02
RMODIF,    1,91, 0.10000000E+11
RMODIF,    1,93, 0.19029028E+01
RMODIF,    1,96, 0.10000000E+11
RMODIF,    1,100, 0.10000000E+11
RMODIF,    1,103, 0.10000045E+11
RMODIF,    1,105, 0.10000045E+11
RMODIF,    1,125, 0.24000000E+01
EMODIF,ALL,REAL,    1
EMODIF,ALL,TYPE,    1 -
May 11, 2024 at 5:08 am
Long Song
SubscriberI met the same problem.
May 20, 2024 at 2:01 pm
Ashish Khemka
Forum ModeratorÂ
Which version of Ansys are you using? SHELL99 is no longer supported in the current version.
Ashish Khemka
May 23, 2024 at 8:29 am
fang pc
SubscriberThank you for your answer. I am using version ANSYS191. By the way, may I ask which element should be used to replace the current version
May 23, 2024 at 9:01 am
Ashish Khemka
Forum ModeratorYou can try Shell 281.
Ashish Khemka
May 24, 2024 at 3:05 am
fang pc
SubscriberThank you for your answer. If I continue to use shell99, can you solve the problem of my input matrix? Or the new version which element can input the matrix
- The topic ‘input A B D E F matrix for SHELL99’ is closed to new replies.
6024
