October 22, 2024 at 7:16 pm
andrewl
SubscriberHi,
I'm injecting 700 inert water particles (not parcel) using cone injection (because I need to change spray angle).
- Particles Diameter: 0.1 mm
- Stop time : 0.05s
- Total flow rate 5.86e-5
- Number of stream: 700 (track individual particles)
However, my console showed number tracked ~4000, not sure its particles or parcel. But this is way higher than 700.
Here is my setting, can anyone please help me how can I inject specific number of particles using cone injection, thank you.
October 22, 2024 at 10:42 pm
andrewl
SubscriberHere is what showing in the console
Updating solution at time level N...
done.
Injecting 700 particle parcels with mass 2.93e-08 at t = 0.008
number tracked = 3952
Eulerian wall film particles:
absorbed = 697
October 23, 2024 at 9:04 am
Forum ModeratorThat will inject 700 parcels per particle time step, and 697 have hit the film. Can you check you don't have splashing on? Note, we always work with parcels and those parcels may be lighter/heavier than a single particle.Â
October 23, 2024 at 5:53 pm
andrewl
Subscriberis it possible to inject just exactly 700 particles ?Â
working with parcel in this case makes me difficult to control how many particles are injected.
Any suggestion how to control the particles injected?
October 23, 2024 at 6:15 pm
andrewl
SubscriberI resolved the issues by making the injection stop time smaller than the time step, this makes it inject only 700 particles.
October 24, 2024 at 9:18 am
Forum ModeratorNo, you have injected 700 parcels. Don't worry about the distinction too much.Â
October 24, 2024 at 5:52 pm
andrewl
SubscriberBut I want each parcel have only 1 particles, thats how i can achieve 700 particles injection.
If I only consider it as injecting 700 parcels, the number tracked in the console will be higher than 700.
Am I understand it correctly? or if you can clarify it a little bit more.
October 29, 2024 at 12:12 pm
Forum ModeratorIf you set the injection mass and only inject for a short period the parcel and particle mass may be equal, but you're still tracking parcels. Why does it matter if you inject more parcels? The results of those trajectories hitting something/escaping is correct, and having more streams generally gives a more stable result.Â
5664
1890
1419
1304
.png)
.png)
