October 27, 2021 at 3:10 pm
nithinnm12345
SubscriberI have a cgns file with species and velocity data. I am trying to initialize a fluent case with this. The number of nodes and the coordinates all match. When I import the file into fluent, only the velocity data gets initialized and I don't get any errors. Is there any way I can initialize the species data as well?
October 28, 2021 at 2:14 pmKarthik Remella
AdministratorHello That's weird! How are you initializing your case using this CGNS file? Would you be able to use a different file format? Have you tried using the Fluent data file (just as a test)?
Karthik
October 29, 2021 at 8:17 amnithinnm12345
SubscriberHi Kremella, reading in a Fluent .dat or .hd5 file works normally.
October 29, 2021 at 2:35 pmKarthik Remella
AdministratorGlad that works. I'm not sure what's happening with the CGNS file. Can you share a screenshot of how you are exporting and reading the CGNS file?
Karthik
October 29, 2021 at 2:47 pmRob
Forum ModeratorWhy CGNS and not a Fluent Interpolation file?
Viewing 4 reply threads- The topic ‘Initializing species data using CGNS’ is closed to new replies.
5754
