July 16, 2024 at 9:30 am
farrokhnezhad
SubscriberHello everyone,
I am currently working on a transient fluid simulation in CFX and I have selected some of the boundary conditions like flow rate over inlet as an input parameter. I am wondering if it would be possible to choose different initilization solution file in Design point update process? And if yes, how can I do that?Â
Thanks a lot for your assistance! -
July 18, 2024 at 11:26 am
V.P
Ansys EmployeeHi Farshid,
Could you check if the Initial values definition section is present under the Execution Control settings in CFX-Pre? You can find this in Insert > Solver > Execution Control > Initial Values > Initial Values Specification. You can use this to specify initial values.
- The topic ‘Initializing design points with different solution files’ is closed to new replies.
