November 26, 2024 at 2:07 pm
enhui.yong.21
SubscriberHello Ansys Learning Support Team,
I used the tutorial provided here https://innovationspace.ansys.com/knowledge/forums/topic/how-to-access-the-value-of-an-expression-at-the-previous-time-step-without-using-userfortran/ to get the value of an expression at the previous timestep without using UserFortan, this was by using a monitor point and arithmetic sum method above. (I didn't used the derivative method as I need to run the simulation in steady as well). I have managed to use this to get the value of p(t-1) and q(t-1) for previous timestep for 3 outlets. Thank you.
As my simulation is unstable at initialisation due to the 2 small outlets, I've had to run a steady simulation to initialise this see below table for variables obtained. The steady simulation also finished with the p(t) and q(t) current timestep which can be used. Then I also defined the p(t-1) and q(t-1) terms to be inialised when starting the transient simulation as it initialises at 0 by the solver by default otherwise (due to automatic with value) causing those 2 small outlets to diverge.
| Courant Number               |  2.27E-05 |  5.65E+02 |
| Density                   |  1.06E+03 |  1.06E+03 |
| Pressure                  |  7.91E+03 |  8.31E+03 |
| pout0prev                  |  8.31E+03 |  8.31E+03 |
| pout1prev                  |  8.31E+03 |  8.31E+03 |
| pout2prev                  |  8.31E+03 |  8.31E+03 |
| qout0prev                  | -9.59E-07 | -9.59E-07 |
| qout1prev                  |  1.13E-06 |  1.13E-06 |
| qout2prev                  |  1.39E-06 |  1.39E-06 |
| Velocity                  |  5.53E-10 |  7.13E-01 |
| Dynamic Viscosity              |  4.00E-03 |  4.00E-03 |However when I now set up the transient model, having tried to create the AVs and linked to default domain expressions, I am now getting this error. I would be very grateful for your assistance and can send the CFX file to an Ansys Employee. This is the error The parameter 'Expression Value' is defined to be Single Valued but it depends on the field variable: qout0prev Error processing expression: Expression Value = pout0
The outfile is also attached https://file.io/lUM5QWd7b99y Â
Outfile
This run of the CFX 2024 R1 Solver started at 13:36:36 on 26 Nov 2024
 by user e_yong on WIN-1 (amd_opteron.sse2_winnt) using the command:
 "C:\Program Files\ANSYS Inc\v241\CFX\bin\perllib\cfx5solve.pl"
  -stdout-comms -batch -ccl -
 2024 R1
 Point Releases and Patches installed:
 Ansys, Inc. License Manager 2024 R1
 Viewer 2024 R1
 Discovery 2024 R1
 Icepak (includes CFD-Post) 2024 R1
 Fluids 2024 R1
 CFD-Post only 2024 R1
 SpaceClaim 2024 R1
 CFX (includes CFD-Post) 2024 R1
 Chemkin 2024 R1
 FENSAP-ICE 2024 R1
 Fluent (includes CFD-Post) 2024 R1
 Polyflow (includes CFD-Post) 2024 R1
 Forte (includes EnSight) 2024 R1
 TurboGrid 2024 R1
 ACIS Geometry Interface 2024 R1
 AutoCAD Geometry Interface 2024 R1
 Catia, Version 4 Geometry Interface 2024 R1
 Catia, Version 5 Geometry Interface 2024 R1
 Catia, Version 6 Geometry Interface 2024 R1
 Creo Elements/Direct Modeling Geometry Interface 2024 R1
 Creo Parametric Geometry Interface 2024 R1
 Inventor Geometry Interface 2024 R1
 JTOpen Geometry Interface 2024 R1
 NX Geometry Interface 2024 R1
 Parasolid Geometry Interface  2024 R1
 Solid Edge Geometry Interface 2024 R1
 SOLIDWORKS Geometry Interface 2024 R1
 Remote Solve Manager Standalone Services 2024 R1
 Sound - SAS 2024 R1
 Setting up CFX Solver run ...
 |           CFX Command Language for Run           |
 LIBRARY:
  CEL:
   EXPRESSIONS:
    LVP = Scaled Left Ventricular Pressure Waveform mmHg 10 cycle 1s \
     period.Pressure(t)
    LVPprev = Scaled Left Ventricular Pressure Waveform mmHg 10 cycle 1s \
     period.Pressure(t-0.001[s] )
    RVP = Scaled Right Ventricular Pressure Waveform mmHg 10 cycle 1s \
     period.Pressure(t)
    RVPprev = Scaled Right Ventricular Pressure Waveform mmHg 10 cycle 1s \
    pout0 = ((areaAve(pout0prev)@OutAorta*(cp0*res0d/dt)) + \
     (res0d*(qout0*(1+(res0p/res0d)+(cp0*res0p/dt))- (qout0prev)* \
     (cp0*res0p/dt))))*(1/(1+(cp0*res0d/dt)))
    pout0prevvalue = probe(Expression Value.Arithmetic \
     Sum)@MPcurrentoutletp - probe(Expression Value)@MPcurrentoutletp
    pout1 = \
     (areaAve(pout1prev)@out1+(qout1*(dt/cp1+res1p+(dt*res1p/(res1d*cp1)))\
     +RVP-RVPprev-((qout1prev)*res1p)))/(1+(dt/(res1d*cp1)))
    pout1prevvalue = probe(Expression Value.Arithmetic Sum)@MPcurrentout1p \
     - probe(Expression Value)@MPcurrentout1p
    pout2 = \
     (areaAve(pout2prev)@out2+(qout2*(dt/cp2+res2p+(dt*res2p/(res2d*cp2)))\
     +LVP-LVPprev-((qout2prev)*res2p)))/(1+(dt/(res2d*cp2)))
    pout2prevvalue = probe(Expression Value.Arithmetic Sum)@MPcurrentout2p \
     - probe(Expression Value)@MPcurrentout2p
    qout0 = -massFlow()@OutAorta/1060 [kg/m^3]
    qout0prevvalue = probe(Expression Value.Arithmetic \
     Sum)@MPcurrentoutletflow - probe(Expression Value)@MPcurrentoutletflow
    qout1 = -massFlow()@out1/1060 [kg/m^3]
    qout1prevvalue = probe(Expression Value.Arithmetic \
     Sum)@MPcurrentqout1flow - probe(Expression Value)@MPcurrentqout1flow
    qout2 = -massFlow()@out2/1060 [kg/m^3]
    qout2prevvalue = probe(Expression Value.Arithmetic \
     Sum)@MPcurrentqout2flow - probe(Expression Value)@MPcurrentqout2flow
    res0 = 1562.5 [g cm^-4 s^-1]
    res0d = 0.91*res0
    res0p = 0.09*res0
    res1 = 72818.6 [g cm^-4 s^-1]*ahyp
    res1d = 0.15*res1
    res1p = 0.84*res1
    res2 = 77316.1 [g cm^-4 s^-1]*ahyp
    res2d = 0.15*res2
    res2p = 0.84*res2
   END
   FUNCTION: Inflow Aorta Mass Flow Rate 10 cycle 1s period
    Argument Units = [s]
    Extend Max = true
    Extend Min = true
    Option = Profile Data
    Spatial Fields = Time
    DATA FIELD: Mass Flow Rate
     Field Name = Mass Flow Rate
     Parameter List = Injection Mass Flow Rate
     Result Units = [g s^-1]
    END
    DATA SOURCE:
     Option = Internal
    END
   END
   FUNCTION: Scaled Left Ventricular Pressure Waveform mmHg 10 cycle 1s \
    period
    Extend Max = true
    Extend Min = true
    DATA FIELD: Pressure
     Field Name = Pressure
     Parameter List = Pressure Profile Shape,Relative Pressure,Relative \
      Pressure in Gas,Relative Static Pressure,Relative Total Pressure
     Result Units = [mmHg]
    END
    DATA SOURCE:
     Option = Internal
    END
   END
   FUNCTION: Scaled Right Ventricular Pressure Waveform mmHg 10 cycle 1s \
    period
    Extend Max = true
    Extend Min = true
    END
    DATA SOURCE:
     Option = Internal
    END
   END
  END
  ADDITIONAL VARIABLE: pout0prev
   Option = Definition
   Tensor Type = SCALAR
   Units = [mmHg]
   Variable Type = Unspecified
  END
  ADDITIONAL VARIABLE: pout1prev
   Option = Definition
   Units = [mmHg]
  END
  ADDITIONAL VARIABLE: pout2prev
   Option = Definition
   Units = [mmHg]
  END
  ADDITIONAL VARIABLE: qout0prev
   Option = Definition
   Units = [m^3/s]
  END
  ADDITIONAL VARIABLE: qout1prev
   Option = Definition
   Units = [m^3/s]
  END
  ADDITIONAL VARIABLE: qout2prev
   Option = Definition
   Units = [m^3/s]
  END
  MATERIAL: Blood
   Material Group = User
   Option = Pure Substance
   PROPERTIES:
    Option = General Material
    EQUATION OF STATE:
     Density = 1060 [kg m^-3]
     Molar Mass = 1.0 [kg kmol^-1]
     Option = Value
    END
    DYNAMIC VISCOSITY:
     Dynamic Viscosity = 0.004 [Pa s]
     Option = Value
    END
   END
  END
 END
 FLOW: Flow Analysis 1
  SOLUTION UNITS:
   Angle Units = [rad]
   Length Units = [m]
   Mass Units = [kg]
   Solid Angle Units = [sr]
   Temperature Units = [K]
   Time Units = [s]
  END
  ANALYSIS TYPE:
   Option = Transient
   EXTERNAL SOLVER COUPLING:
    Option = None
   END
   INITIAL TIME:
    Option = Automatic with Value
    Time = 0 [s]
   END
   TIME DURATION:
    Option = Total Time
    Total Time = 2 [s]
   END
   TIME STEPS:
    Option = Timesteps
    Timesteps = dt
   END
  END
  DOMAIN: Default Domain
   Coord Frame = Coord 0
   Domain Type = Fluid
   Location = simplifiedgeom fluid
   BOUNDARY: InAorta
    Boundary Type = INLET
    Location = from simplifiedgeom to inflow mass flow inlet
    Use Profile Data = False
    BOUNDARY CONDITIONS:
     FLOW DIRECTION:
      Option = Normal to Boundary Condition
     END
     FLOW REGIME:
      Option = Subsonic
     END
     MASS AND MOMENTUM:
      Mass Flow Rate = Inflow Aorta Mass Flow Rate 10 cycle 1s \
       period.Mass Flow Rate(Time)
      Mass Flow Rate Area = As Specified
      Option = Mass Flow Rate
     END
    END
   END
   BOUNDARY: OutAorta
    Boundary Type = OPENING
    Location = from simplifiedgeom to outflow outflow
     FLOW DIRECTION:
     END
     FLOW REGIME:
      Option = Subsonic
     END
     MASS AND MOMENTUM:
      Option = Opening Pressure and Direction
      Relative Pressure = pout0
     END
    END
   END
   BOUNDARY: Wall
    Boundary Type = WALL
    Location = from simplifiedgeom to background wall
     MASS AND MOMENTUM:
      Option = No Slip Wall
     END
    END
   END
   BOUNDARY: out1
    Location = from simplifiedgeom to out1 outlet vent
     FLOW DIRECTION:
     END
     FLOW REGIME:
      Option = Subsonic
     END
     MASS AND MOMENTUM:
      Relative Pressure = pout1
     END
    END
   END
   BOUNDARY: out2
    Location = from simplifiedgeom to out2 outlet vent
     FLOW DIRECTION:
     END
     FLOW REGIME:
      Option = Subsonic
     END
     MASS AND MOMENTUM:
      Relative Pressure = pout2
     END
    END
   END
   DOMAIN MODELS:
    BUOYANCY MODEL:
     Option = Non Buoyant
    END
    DOMAIN MOTION:
     Option = Stationary
    END
    MESH DEFORMATION:
     Option = None
    END
    REFERENCE PRESSURE:
     Reference Pressure = 0 [atm]
    END
   END
   FLUID DEFINITION: Fluid 1
    Material = Blood
    Option = Material Library
    MORPHOLOGY:
     Option = Continuous Fluid
    END
   END
   FLUID MODELS:
     Additional Variable Value = pout0prevvalue
     Option = Algebraic Equation
    END
     Additional Variable Value = pout1prevvalue
    END
     Additional Variable Value = pout2prevvalue
    END
     Additional Variable Value = qout0prevvalue
    END
     Additional Variable Value = qout1prevvalue
    END
     Additional Variable Value = qout2prevvalue
    END
    COMBUSTION MODEL:
     Option = None
    END
    HEAT TRANSFER MODEL:
     Option = None
    END
    THERMAL RADIATION MODEL:
     Option = None
    END
    TURBULENCE MODEL:
     Option = Laminar
    END
   END
  END
  INITIALISATION:
   Option = Automatic
   INITIAL CONDITIONS:
    Velocity Type = Cartesian
    CARTESIAN VELOCITY COMPONENTS:
     U = 0 [m s^-1]
     V = 0 [m s^-1]
     W = 0 [m s^-1]
    END
    STATIC PRESSURE:
     Relative Pressure = 63 [mm Hg]
    END
   END
  END
  OUTPUT CONTROL:
   MONITOR OBJECTS:
    MONITOR BALANCES:
     Option = Full
    END
    MONITOR FORCES:
     Option = Full
    END
    MONITOR PARTICLES:
     Option = Full
    END
    MONITOR POINT: MPcurrentout1p
     Expression Value = pout1
     Option = Expression
     MONITOR STATISTICS:
      Allow Running Statistics = On
      Option = Moving Interval
      Statistics List = Arithmetic Sum
      INTERVAL DEFINITION:
       Number of Timesteps = 2
       Option = Timesteps
      END
     END
    END
    MONITOR POINT: MPcurrentout2p
     Expression Value = pout2
     Option = Expression
     MONITOR STATISTICS:
       Option = Timesteps
      END
     END
    END
    MONITOR POINT: MPcurrentoutletflow
     Expression Value = qout0
     Option = Expression
     MONITOR STATISTICS:
       Option = Timesteps
      END
     END
    END
    MONITOR POINT: MPcurrentoutletp
     Option = Expression
     MONITOR STATISTICS:
       Option = Timesteps
      END
     END
    END
    MONITOR POINT: MPcurrentqout1flow
     Expression Value = qout1
     Option = Expression
     MONITOR STATISTICS:
       Option = Timesteps
      END
     END
    END
    MONITOR POINT: MPcurrentqout2flow
     Expression Value = qout2
     Option = Expression
     MONITOR STATISTICS:
       Option = Timesteps
      END
     END
    END
    MONITOR POINT: MPpreviousout1p
     Expression Value = pout1prevvalue
     Option = Expression
    END
    MONITOR POINT: MPpreviousout2p
     Expression Value = pout2prevvalue
     Option = Expression
    END
    MONITOR POINT: MPpreviousoutletflow
     Expression Value = qout0prevvalue
     Option = Expression
    END
    MONITOR POINT: MPpreviousoutletp
     Expression Value = pout0prevvalue
     Option = Expression
    END
    MONITOR POINT: MPpreviousqout1flow
     Expression Value = qout1prevvalue
     Option = Expression
    END
    MONITOR POINT: MPpreviousqout2flow
     Expression Value = qout2prevvalue
     Option = Expression
    END
    MONITOR POINT: Monitor Point 1
     Cartesian Coordinates = 0.00572361 [m], -0.00108951 [m], 0.0484329 [m]
     Option = Cartesian Coordinates
     Output Variables List = Absolute Pressure
     MONITOR LOCATION CONTROL:
      Interpolation Type = Nearest Vertex
     END
     POSITION UPDATE FREQUENCY:
      Option = Initial Mesh Only
     END
    END
    MONITOR POINT: Monitor Point LAD
     Cartesian Coordinates = 0.0568741 [m], -0.00608401 [m], 0.0129885 [m]
     END
     END
    END
    MONITOR POINT: Monitor Point RCA
     Cartesian Coordinates = -0.0412365 [m], -0.0119797 [m], 0.0153338 [m]
     END
     END
    END
    MONITOR RESIDUALS:
     Option = Full
    END
    MONITOR TOTALS:
     Option = Full
    END
   END
   RESULTS:
    File Compression Level = Default
    Option = Standard
   END
   TRANSIENT RESULTS: Transient Results 1
    Include Mesh = No
    Option = Selected Variables
    Output Variables List = Pressure,Velocity
    OUTPUT FREQUENCY:
     Option = Time List
     Time List = 1 [s], 1.01 [s], 1.02 [s], 1.03 [s], 1.04 [s], 1.05 [s], \
      1.06 [s], 1.07 [s], 1.08 [s], 1.09 [s], 1.1 [s], 1.11 [s], 1.12 \
      [s], 1.13 [s], 1.14 [s], 1.15 [s], 1.16 [s], 1.17 [s], 1.18 [s], \
      1.19 [s], 1.2 [s], 1.21 [s], 1.22 [s], 1.23 [s], 1.24 [s], 1.25 \
      [s], 1.26 [s], 1.27 [s], 1.28 [s], 1.29 [s], 1.3 [s], 1.31 [s], \
      1.32 [s], 1.33 [s], 1.34 [s], 1.35 [s], 1.36 [s], 1.37 [s], 1.38 \
      [s], 1.39 [s], 1.4 [s], 1.41 [s], 1.42 [s], 1.43 [s], 1.44 [s], \
      1.45 [s], 1.46 [s], 1.47 [s], 1.48 [s], 1.49 [s], 1.5 [s], 1.51 \
      [s], 1.52 [s], 1.53 [s], 1.54 [s], 1.55 [s], 1.56 [s], 1.57 [s], \
      1.58 [s], 1.59 [s], 1.6 [s], 1.61 [s], 1.62 [s], 1.63 [s], 1.64 \
      [s], 1.65 [s], 1.66 [s], 1.67 [s], 1.68 [s], 1.69 [s], 1.7 [s], \
      1.71 [s], 1.72 [s], 1.73 [s], 1.74 [s], 1.75 [s], 1.76 [s], 1.77 \
      [s], 1.78 [s], 1.79 [s], 1.8 [s], 1.81 [s], 1.82 [s], 1.83 [s], \
      1.84 [s], 1.85 [s], 1.86 [s], 1.87 [s], 1.88 [s], 1.89 [s], 1.9 \
      [s], 1.91 [s], 1.92 [s], 1.93 [s], 1.94 [s], 1.95 [s], 1.96 [s], \
      1.97 [s], 1.98 [s], 1.99 [s], 2 [s]
    END
   END
  END
  SOLVER CONTROL:
   ADVECTION SCHEME:
    Option = High Resolution
   END
   CONVERGENCE CONTROL:
    Maximum Number of Coefficient Loops = 20
    Minimum Number of Coefficient Loops = 3
    Timescale Control = Coefficient Loops
   END
   CONVERGENCE CRITERIA:
    Residual Target = 1e-5
    Residual Type = RMS
   END
   INTERRUPT CONTROL:
    Option = Any Interrupt
    CONVERGENCE CONDITIONS:
     Option = Default Conditions
    END
   END
   TRANSIENT SCHEME:
    Option = Second Order Backward Euler
    TIMESTEP INITIALISATION:
     Option = Automatic
    END
   END
  END
 END
 COMMAND FILE:
  Version = 24.1
  Results Version = 24.1
 END
 SIMULATION CONTROL:
  EXECUTION CONTROL:
   EXECUTABLE SELECTION:
    Double Precision = Yes
    Large Problem = No
   END
   INTERPOLATOR STEP CONTROL:
    Runtime Priority = Standard
    MEMORY CONTROL:
     Memory Allocation Factor = 1.0
     Option = Model Based
    END
   END
   PARALLEL HOST LIBRARY:
    HOST DEFINITION: win1
     Remote Host Name = WIN-1
     Host Architecture String = winnt-amd64
     Installation Root = C:\Program Files\ANSYS Inc\v%v\CFX
    END
   END
   PARTITIONER STEP CONTROL:
    Multidomain Option = Automatic
    MEMORY CONTROL:
    END
    PARTITION SMOOTHING:
     Maximum Partition Smoothing Sweeps = 100
     Option = Smooth
    END
    PARTITIONING TYPE:
     MeTiS Type = k-way
     Option = MeTiS
     Partition Size Rule = Automatic
     Partition Weight Factors = 0.08333, 0.08333, 0.08333, 0.08333, \
      0.08333, 0.08333, 0.08333, 0.08333, 0.08333, 0.08333, 0.08333, \
      0.08333
    END
   END
   RUN DEFINITION:
    Run Mode = Full
    Solver Input File = D:\Temp\e_yong\CFD\Monitor Point Way 2\Better \
     initialise\SimplifiedGeometryBase_MP_3EWKIMP_complex_alldone_inied_be\
     t2.def
    Solver Results File = D:\Temp\e_yong\CFD\Monitor Point Way 2\Better \
     t2_001.res
    INITIAL VALUES SPECIFICATION:
     INITIAL VALUES CONTROL:
      Use Mesh From = Solver Input File
     END
     INITIAL VALUES: Initial Values 1
      File Name = D:/Temp/e_yong/CFD/Monitor Point Way 2/Better \
       initialise/SimplifiedGeometryBase_MP_3EWKIMP_complex_alldone_ini_\
       bet_001.res
      Option = Results File
     END
    END
   END
   SOLVER STEP CONTROL:
    MEMORY CONTROL:
    END
    PARALLEL ENVIRONMENT:
     Number of Processes = 12
     Start Method = Intel MPI Local Parallel
     Parallel Host List = win1*12
    END
   END
  END
 END
 |          Interpolation of Initial Values          |
 |           ANSYS(R) CFX(R) Interpolator           |
 | 2024 R1                               |
 | Build 24.1 2023-11-06T16:24:29.753953                |
 | Mon Nov  6 17:03:59 GMTST 2023                   |
 |             Executable Attributes            |
 |      double-64bit-int32-archfort-optimised-std-lcomp      |
 | (C) 1996-2024 ANSYS, Inc.                      |
 | All rights reserved. Unauthorized use, distribution or duplication |
 | is prohibited. This product is subject to U.S. laws governing    |
 | export and re-export. For full Legal Notice, see documentation.   |
 +--------------------------------------------------------------------+ Â
 |          Job Information at Start of Run          |
 +--------------------------------------------------------------------+  Run mode:    serial run  Host computer:  WIN-1 (PID:288020)  Job started:   Tue Nov 26 13:36:38 2024
 |     Initial Memory Allocation  (Actual usage may vary)     |
 +--------------------------------------------------------------------+       | Real    | Integer   | Character | Logical  | Double
 Mwords   |    30.40 |    36.19 |    0.20 |   0.01 |   0.30
 Mbytes   |   231.95 |   138.05 |    0.19 |   0.04 |   2.29
 |       Host Memory Information (Mbytes): Interpolator      |
 |      Host      |   System   |  Allocated   |  %   |
 | WIN-1          |   523878.43  |    372.52  |  0.07 |
        Interpolating Onto Domain "Default Domain"
 ======================================================================  Total Number of Nodes in the Target Domain        =    552268
 Bounding Box Volume of the Target Mesh          =  1.42880E-04
 Checking all source domains from the source file:
  Target mesh is the same as domain "Default Domain".  Start direct copying of variables from domain "Default Domain".  +--------------------------------------------------------------------+
 |           Variable Range Information           |
 |    Variable Name             |   min   |   max   |
 | Courant Number               |  2.27E-05 |  5.65E+02 |
 | Density                   |  1.06E+03 |  1.06E+03 |
 | Pressure                  |  7.91E+03 |  8.31E+03 |
 | pout0prev                  |  8.31E+03 |  8.31E+03 |
 | pout1prev                  |  8.31E+03 |  8.31E+03 |
 | pout2prev                  |  8.31E+03 |  8.31E+03 |
 | qout0prev                  | -9.59E-07 | -9.59E-07 |
 | qout1prev                  |  1.13E-06 |  1.13E-06 |
 | qout2prev                  |  1.39E-06 |  1.39E-06 |
 | Velocity                  |  5.53E-10 |  7.13E-01 |
 | Dynamic Viscosity              |  4.00E-03 |  4.00E-03 |
 |      Host      |   System   |    Peak    |  %   |
 | WIN-1          |   523878.43  |     81.72  |  0.02 |
 |        CPU Time Requirements of Interpolator         |
  Interpolation Step        Time   Percentage
                (secs.  %total)
 Tree Setup           2.75E-01  18.2 %
 Interpolation          4.20E-02   2.8 %
 Miscellaneous          1.19E+00  79.0 %
 Total              1.51E+00  +--------------------------------------------------------------------+
 |          Job Information at End of Run           |
 +--------------------------------------------------------------------+  Host computer:  WIN-1 (PID:288020)  Job finished:  Tue Nov 26 13:36:39 2024  Total wall clock time: 8.370E-01 seconds
       or: (      0:     0:     0:   0.837 )
         (    Days:   Hours:  Minutes:  Seconds ) The parameter 'Expression Value' is defined to be Single Valued but it depends on the field variable: qout0prev
 |         An error has occurred in cfx5solve:         |
 | C:\Program Files\ANSYS                       |
 | Inc\v241\CFX\bin\winnt-amd64\double\ccl2flow.exe was interrupted  |
 | by signal QUIT (3)                         |
This run of the ANSYS CFX Solver has finished. Â Â -
December 9, 2024 at 1:43 pm
V.P
Ansys EmployeeHi,
It seems that the expression
pout0has inadvertently connected toqout0prev. I kindly request you to carefully review all the expressions, as this may be a minor issue that can likely be resolved with a thorough check.
