July 20, 2023 at 2:49 pm
Geardyn 1
Subscriberhi all,Â
I have a gear pair model consisting of solid elements, which is used to simulate wear behaviour.Âwe have followed all the steps as mentioned by the following pdf : simulation-of-wear-processes-in-ls-dyna.pdf
INTFOR is showing the Wear slide & Depth Fringe , but the issue is that inspite of adding the following cards , Â *INITIAL_CONTACT_WEAR data is not been written in the dynain file.Cards used :
*CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_ID (SPR/MPR are set to 2)
*CONTACT_ADD_WEAR (above contact cid is added with p1,p2,p3)
*DATABASE_EXTENT_INTFOR (nwear=2)
*INTERFACE_SPRINGBACK_LSDYNA (PSID is mentioned).....Â
thanks in advance.Â
July 20, 2023 at 3:13 pm
- The topic ‘*INITIAL_CONTACT_WEAR data is not written in dynain file’ is closed to new replies.
