October 25, 2023 at 12:31 am
Raul Jr. Regis
SubscriberI am simulating a cold storage room with an initial temperature of -17C. The objects inside the room are initially -5C using patch. There is also an inlet air of -24C and runs for 20 minutes. my problem is the temperature of the objects stay at -5C even after 20 min. I am still learning the basics but this is the project and problem I have encountered for now. Thank you so much for any help.
October 25, 2023 at 12:50 am
Raul Jr. Regis
SubscriberHere is the drive link containing the archive of my project
https://drive.google.com/file/d/1t0pGoAXarXN-RvPstj3PTUcYwIDExlUg/view?usp=sharing
October 25, 2023 at 8:50 am
Forum ModeratorStaff aren't permitted to download or open any files - it's a requirement from legal to allow us to answer questions.
Can you show the cell zone condition of the cold zone? If you check fluxes do you see any heat transfer between zones?
October 26, 2023 at 1:34 am
Raul Jr. Regis
October 26, 2023 at 10:29 am
Forum ModeratorThat's the air cell zone condition. What's the solid set as?
October 26, 2023 at 11:42 pm
October 27, 2023 at 8:49 am
Forum ModeratorThat's correct.
Can you plot temperature and velocity as per the first image in the thread in Fluent, but plot with node values off. You settings look OK from what you've shown me, so we need to focus on what's going on in the domain.
November 3, 2023 at 12:21 am
November 3, 2023 at 12:10 pm
Forum ModeratorHard to tell without reviewing the whole model, and I can't do that due to the contraints we work to on here. Node values are easier to find in the Fluent post processing.
November 4, 2023 at 12:18 am
November 7, 2023 at 3:36 pm
November 8, 2023 at 12:35 am
November 8, 2023 at 9:40 am
Forum ModeratorDisplaying on the interior domains isn't recommended as it's the default label for all cell facets so can cause the computer to crash as the graphics load becomes rather high. In this case it looks to show the blocks are cooling, albeit slowly. Look under the "New Surface" option to create iso-surfaces (of mesh) or planes to replicate the CFD Post image.
I'd only use Total Temperature for compressible systems, Static is usually sufficient.
November 9, 2023 at 2:39 am
November 9, 2023 at 8:49 am
Forum ModeratorOK, so looking at that you’ve got virtually no flow around the hot part, and all of the flow goes “over” the section that needs cooling. So, what is between the air flow and warm blocks? It also looks like the inlet condition is adjacent to a wall? That’s not a good idea, unless that’s how the system was designed?
To add, you really want to be getting IT to install 2023R2: R19.2 is about 5 years old now.
- The topic ‘Initial temperature of an object does not change’ is closed to new replies.
5934
1306
