TAGGED: ansys-mechanical-apdl, ansys-thermal, transient
October 20, 2023 at 4:23 pm
Jeremy
SubscriberI am working on are initial temperature problem using the transient thermal module.
To assign initial temperature in different locations,
- Calculate an initial temperature rise.Â
- Create little volumes in CAD for the intended temperature distribution.
- Create Named sections for each volume in the module. Â
- Assign an average temperature for each little volume using APDL command: CMSEL,s,volumename, and IC, volumename, TEMP, temperaturevalue.
Instead of performing the above, can ANSYS import using a temperature field function T(x,z) or T(x,y,z) as an initial temperature condition?
October 21, 2023 at 10:26 am
peteroznewman
Subscriber-
October 23, 2023 at 5:27 am
Jeremy
SubscriberGreat, thanks! Got it to work!Â
- The topic ‘Initial temperature field problem in transient thermal module’ is closed to new replies.
- BackGround Color
- Contact stiffness too big
- Element Birth and Death
- Python-Script to Export all Children of a Solution Tree
- Which equations and in what form are valid for defining excitations?
1495
1386
1209
