November 18, 2023 at 11:22 am
Alberto
SubscriberHi,
It is possible to use the .dat and .cas files from the last saved timestep and use as initial condition for a new simulation ? Also if the mesh is changed ?
Many thanks in advance
November 20, 2023 at 1:42 pm
Federico
Ansys EmployeeHello,
yes you can read .cas and .dat files together and run from there. You can also read a .dat file on a new mesh, as long as this new mesh has the same topology as the previous mesh, i.e. same zones, etc.
November 20, 2023 at 1:43 pm
Federico
Ansys EmployeeFluent will interpolate/extrapolate the data between nodes, depending if your new mesh is finer/coarser.
November 20, 2023 at 4:41 pm
Alberto
SubscriberMany thanks, yes I want to change the size of the computational domain in order to elongate it, so the mesh will change but the zones no.
- The topic ‘Initial condition from another simulation’ is closed to new replies.
1885
1404
1303
