November 27, 2022 at 11:29 am
Krish Gajjar
SubscriberHello friends.
I want to do a transient analysis of a disc brake (during braking). But ANSYS GUI is not allowing me to input the initial angular velocity to the disc (it's Greyed out).Â
Also, the commands option is greyed out. What should I do?How should I proceed with the analysis of the results?
Thanks in Advance...
November 27, 2022 at 1:50 pm
peteroznewman
SubscriberDo you have a Revolute Joint on the disc?
Apply a Joint Load on that Revolute Joint of type Rotational Velocity
Use a 4 step solution process.
Step 1, ramp the Rotational Velocity from 0 to the desired value in 0.9 seconds.
Step 2, hold the Rotational Velocity constant for 0.09 seconds.
Step 3, Deactivate the Joint Load (unless you want it active) in 0.01 seconds.
Step 4, Apply the brakes!
All your braking data will start at t=1.00 seconds.
November 27, 2022 at 2:50 pm
November 27, 2022 at 4:45 pm
peteroznewman
- The topic ‘Initial Angular Velocity in Transient Structural’ is closed to new replies.
5934
1306
.png)
.png)
