May 4, 2018 at 8:27 am
tnegem
SubscriberHiÂ
I would like to know if anyone has any knowledge about using INISTATE command, As I am trying to use it to insert an initial stress state but which varies spatially
June 15, 2018 at 11:52 pm
April Wang
Ansys EmployeeHi tnegem,
You can check out the example for INISTATE in ANSYS. It located at:Â
ANSYS Help Documentation-->Mechanical APDL-->Advance Analysis Guide
Chapter 5: Initial State
5.6. Example Problems Using Initial State
5.6.2. Example: Initial Stress (INISTATE Command)
April
December 15, 2019 at 2:11 pm
Gijoys4v
SubscriberFrom where I can get ANSYS Help Documentation. can you share the link please?
December 15, 2019 at 3:03 pm
peteroznewman
SubscriberOn the Start Menu under the ANSYS Folder is ANSYS Help.
In Workbench, there is a Help menu.
In Mechancial, there is a ? icon on the top right corner.
December 20, 2019 at 3:26 pm
Gijoys4v
Subscriber -
December 21, 2019 at 3:24 pm
Gijoys4v
SubscriberFor the above question, I gaveÂ
solid1"_sid   in the geometry section of the above solid as command and gave the following command
inis,set,csys,-2
inis,set,mat,matid
inis,set,dtype,epel
inis,defi,,,,,-1.363e-3,-1.3063e-3,4.9759e-3,-1.363e-3,-1.3063e-3,4.9759e-3,-1.363e-3,-1.3063e-3,4.9759e-3
so it selected applied the strain value to top solid. If I have to assign a different strain to the second body ; how can I do this?
December 21, 2019 at 5:16 pm
peteroznewman
SubscriberYou can drag this command object from under the first solid and drop it on the second solid and the third solid, then each body will have a command object under it. They are each independent so you can edit each one.
- The topic ‘INISTATE Command’ is closed to new replies.
5904
1306
