Inhomogenous process distribution on multiple machine error
    • Kimoo1135
      Hello everyone,
      So I am trying to solve using parallel processing and when I set the number of gpgpus to 1 I have this error “Inhomogenous process distribution on multiple machine error or processes per machine not an exact multiple of gpgpus per machine or not enough gpgpus per machine. Gpgpus computing disabled”
      I have NVIDIA Quadro K2000/ 2 Sms/0.954 GHz/ 2.14748 Gbytes. Also, when I use the parallel/gpgpu/select command it shows”invalid command [select]
      I am using Ansys 15.0. Thank you
    • Amine Ben Hadj Ali
      Please update to a supported and new release. 15.0 is very old.
      Moreover the Number of processes be an exact multiple of number of GPUs.
    • Julio Gutierrez
      Hi There, I have the same Problem, but using the 2023R1 Version. I developed the model in 2021R1 Version using 8 and 8, but I want to run my model in another computer. The new computer have both 2021R1 (and I can open the model with this version with 4 and 4) and 2023R1 (with this version I get the problem)
    • Julio Gutierrez
      showed text: Host spawning Node 0 on machine "Ansys-HP" (win64). Error: eval: unbound variable Error Object: Inhomogeneous process distribution on multiple machines. Or processes per machine not an exact multiple of GPGPU's per machine. Or not enough GPGPU's per machine. GPGPU computing disabled.
  • The topic ‘Inhomogenous process distribution on multiple machine error’ is closed to new replies.
