Information about Fluent Equations from Theory Guide
    • soloviev
      I am interested in some things that I could not find in the theory guide:
      1. Gravity is set in operating conditions, and is not included in equations such as the Navier-Stokes equation in the LES model. How do these interact to ensure the eddies are influenced by gravity in the model?
      2. In the VOF model, the incident wave profile uses Kx and Ky, which are defined as Kx=kcos(theta) and ky=ksin(theta). I can't find what theta is defined as anywhere in the theory guide for these equations?
      3. For the wave frequency in the open channel flow, it says U is the uniform incident wave velocity. I see no further explanation on how this was defined?
      Thanks,
      Alex
    • DrAmine
      Gravity term is treated as source term. Once activated Fluent will redefine the pressure as documented in the Pressure Inlet description.
      Theta is the angle between the wave front and reference propagation direction (the latter default is flow direction). Zero being the default
      Vector U the referring the main flow velocity (background velocity) like you have 5 m/s of bulk water flow flowing in certain direction
    • soloviev
      Thank you.
      This answered my questions!
  • The topic ‘Information about Fluent Equations from Theory Guide’ is closed to new replies.
