3D Design
3D Design
Information
    • Roberto
      ? This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      Hello I have a customer who saves files on the server and has noticed that SpaceClaim automatically saves autosave. If I try to open them, the file is empty? What are these saves that it does automatically without consent. I thought they were the Back_up files but they are not those as the customer is using the default path C:UsersLucasAppDataRoamingSpaceClaimAutosave   Best Regards
    • Subashni Ravichandran
      Hello Roberto Can you please confirm the autosave location in SpaceClaim settings? Does the customer see this issue only while saving a file directly on server or does this happen in the local machine also? Could it be possible that the server is not allowing the backup files to get automatically deleted as per 'Keep backup files for' option?
    • Roberto
      Subashni Hello
      The autosave location is confirmed.
      It only happens on the server.
      Should Keep backup files be deactivated?.
      can I delete the backup files without damaging the original files?
      Best Regards
      Hello Roberto
      I don't think deleting backup files should affect the original file. Please ensure you have saved your file before deleting the backup.
      Also, yes, please try turning off backup and check if this issue is occurring again. If it does, I can get in touch with the development team on this.
    • Roberto
      Hello Subashni
      I try to do this test, if the customer wants to keep the Back_up save, however, there will be a solution to be found.
      Best regards
    • Roberto
      Hello Subashni
      The customers has disabled on both computer the backup file. Too this morning the customers have find the files on the server. I wait for the answered for resolving this problem
      Best Regards
    • Roberto
      Hello Subashni
      Let me know if you've read the messages
      Best Regards
      Hello Roberto
      Sorry for the delay. Let me follow up with my team and get back to you.
      Hello Roberto
      Does this happen with multiple users with the same setup or only for one specific user?
      Also, can you please copy the autosaved file to a different location, rename it(remove 'autosave' from file name) and try opening it?
    • Roberto
      Hello Subashni
      The problem occurs on both computers.
      Changing the name opens the file, so what can it be?
      Best Regards
    • Roberto
      Hello Subashni If I open the files by changing the name, SpaceClaim says it's an educational license which isn't true
    • Roberto
      Hello Subashni
      We found that the files are created on the server when opened with the SpaceClaim viewer.
      Is there a way not to have them created?
      You can give me an answer in a short time
      Best Regards
    • Roberto
      Hello Subashni Charudatta Bandgar
      The customer solicits an answer has been waiting for a long time
      Best Regards
      Hello Roberto
      The best practice would be to copy the files on the local machine and use them.
      As you mention this issue is occurring with SpaceClaim Viewer, and as SpaceClaim Viewer is not being developed currently, I cannot raise a bug here.
Viewing 13 reply threads
  • The topic ‘Information’ is closed to new replies.
