August 20, 2019 at 10:13 pm
asamaiyar
SubscriberHi,Â
Are there Technical Notes about how Infinite Ground works with Master-Slave Boundaries in HFSS? Is it even recommended to use Infinite Ground option with Master Slave boundaries?
Thanks,
Aman
September 4, 2019 at 4:15 pm
slouie
Ansys EmployeeHFSS will solve for currents on the finite ground plane that you have physically defined in the model, but when calculating far fields, it will take into account the "infinite ground" option if you've selected it. In other words, radiated fields are the only result affected by the infinite ground option - the infinite ground option does not change what's happening during the HFSS solve process; only the radiated field calculations that occur after the solve process will be affected (like when you plot far fields for example).Â
September 4, 2019 at 6:57 pm
asamaiyar
SubscriberGreat. Thank you for the response.
Is it okay to use infinite ground plane with Master-Slave boundaries?Â
September 20, 2019 at 10:35 pm
slouie
Ansys EmployeeYes, that should be fine.
- The topic ‘Infinite Ground with Master Slave Boundaries’ is closed to new replies.
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
3862
1414
1221
1118
1015
