October 19, 2020 at 4:00 pm
JeromeTeoh
SubscriberHi,nQuestions regarding the induction simulation in Ls-Dyna, I read about there are 3 heat mechanisms for thermoplastic: joule heating, junction heating-dielectric hysteresis and junction heating-contact resistance.nSo, is Ls-dyna induction solver can account these three heat mechanism in simulation or is there any way that I need to change my model to be able to get my model close to accurate?n n -
October 20, 2020 at 3:02 pm
icaldich
Ansys EmployeeDear Jerome,nnThe first and the last one (i.e Joule heating and contact resistance heating) are available but not dielectric hysteris.nnBest,nnInakinn
- The topic ‘Induction heating in Ls-Dyna’ is closed to new replies.
Ansys Innovation Space
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
1414
1256
1118
1015
