August 26, 2025 at 12:24 pm
batuhan.akbas
SubscriberHello All,
Is it possible in Ansys Discovery to assign different internal emissivity values inside for Fluid-Solid interfaces?I created a simple case in order to check this but all I can do assign an emissivity value to all of the Fluid-Solid interfaces and not indivually.The image below is a simple CHT problem, where the red sphere represent heater and this heater is enclosed in a solid volume. Naturally, the fluid volume between them is also modeled.Â
The tool can find the interfaces but not assign any indivual parameter. Also, can we only define emissivity of 1.0 in Refine mode for internal emissivity?
Best,
Batu -
August 28, 2025 at 7:47 am
Atharv Joshi
Forum ModeratorHi Batu,
Currently, you cannot split and apply different emissivity values to the fluid-solid interfaces. We have communicated this enhancement to the development.
Yes, in the refine stage the internal emissivity will be idealized to 1.ÂRegards
Atharv
3777
1388
1173
1090
1015
