Photonics
Photonics
independent and nested parametric sweep
    • bibin.babu
      i have usd the default sweep settings in the diffusive scattering film for automotive display example (Diffuse Scattering Film for Automotive Display – Ansys Optics). Since my GPU crashes when I run the sweep. I have made as different independant sweep instead of nested sweep (without and with operation in result GUI). Does this affects the results in exporting the brdf file? if Yes, how should be the scipt changed to post process the results?
    • Kirill
      Dear Subscriber,
      In order to assist you better, could you please share the following:
      Which operating system and version of Lumerical are you using? Please send a screenshot of the Lumerical CAD > Help > About... page, which provides this information (like this image).
      Thank you!
    • bibin.babu
      [ The image has been deleted. ]
      Dear Kirill,
      Thank You for the instant reply. here’s the OS and Lumerical version I am using.
      Bibin
    • Kirill
      Dear Bibin,
      Thank you for the confirmation! You should be eligible for customer support through ACSS, see How to register and access technical support on Ansys Customer Support Space. Please submit the request there.
      Best regards,
      Kirill
