Increasing the interval between ticks in CFDPost
    • scabo
      Hi
      I want to increase the interval between the ticks in CFDPost (fluent results). I have set the number of contours to 16, so it is creating a lot of data ticks on the legend, but i want around 4. But it is not working like that. How can i reduce the number of ticks on CFDPost Legend without reducing the number of contours? any help is appreciated , thanks!
    • V.P
      Hi scabo,
      Actually, you can edit the Legend to have just 4 ticks. In the legend settings, you can find the option to edit the Value ticks. You can set this as 4. But this will not be applicable for contours. It is applicable for others like vectors, streamlines etc.
      The workaround is to create contour and also vector plot on the same surface. Now right click on vectors and Insert a new legend. In this legend specify the ticks. Specify the vector variable range same as that of contour. Now turn off the Default legend and vector. Now you have contour having a legend with just 4 value ticks.
    • scabo
      I think that works thanks very much.
    • scabo
      Also i am trying to save the contour plots. What is the best way to save so that i will get a very high resolution image? PNG seems compressed.
    • V.P
      Hi scabo,
      PNG is a lossless format compared to JPEG.
      To increase the resolution:
      In the Save Picture dialogue box, uncheck "Use Screen Size", option. Now, the Image Size option becomes active. In the image size drop-down menu, choose 8K or 4K. Now save.
    • scabo
      If i increase the scaling to 500, 600 without unticking the screen size option
    • scabo
      Then also it works i think
    • scabo
      There is no option to save it in 4K or 8K size, just we can change the screen size X and Y values.
    • scabo
      Also in the legend contour plot, we cant give subscript and superscript in CFDPost
Viewing 8 reply threads
