July 12, 2024 at 8:35 am
mashetty
SubscriberHello,ÂÂI am working on a Directed Energy Deposition (DED) simulation using ANSYS Additive Suite. I am following the example provided in the ANSYS documentation for a racetrack DED simulation. I have set the time steps as shown in the provided image.ÂÂ However, my simulation results are not following the specified substep order. Instead, I am only getting a very few time step points , shown in the image.How can I change the time steps to get more detailed results instead of only getting results at particular intervals as highlighted in the above image(For time step : 7.001,9.334,10.113...)? For example if i need to get a temperature result for every one second (For example at time step 1,2,3,4,....) or for every 5 second, How can i do it.ÂÂÂ
July 23, 2024 at 10:54 am
Ashish Khemka
Forum ModeratorHi,
You can try reducing the maximum time step size and see if that helps.
Ashish Khemka
July 25, 2024 at 10:38 am
mashetty
SubscriberÂ
Hi Ashish,  I have tried changing the max time step size values, however no change in the results. Same time step results are seen, with no difference. Do you have any other suggestions.
- The topic ‘Increase the Number of Time Step Points in ANSYS Additive for DED Simulation’ is closed to new replies.
