Increase the maximum number of equilibrium iterations per solution step in Mechanical
    • vganore
      How to increase the maximum number of equilibrium iterations per solution step in Mechanical?
    • cbhavsar
      The maximum number of equilibrium iterations per each solution point is 25 based on the default setting of the NEQIT command. To change the maximum number of equilibrium iterations, you can issue the NEQIT command from within a Command Object. For example, issuing NEQIT,30 will increase the maximum number of equilibrium iterations to 30.
    • unknown
      what is the command line to control the iteration numbers?
    • Gary Wang
      https://www.ansystips.com/2017/09/increasing-number-of-iteration-per.html
      you can refer to the link above to add the Command object with NEQIT,30 in it.
  • The topic ‘Increase the maximum number of equilibrium iterations per solution step in Mechanical’ is closed to new replies.
