August 11, 2020 at 6:45 am
Ishan
SubscriberI am doing a transient simulation in ANSYS Fluent. Setup in fluent (and hence computation) is done using double precision. However when I am writing the pressure data (for each time step) in a separate notepad file using console commands, I get a single decimal precision. How can this precision be increased? I see that when I export chart data from fluent in a CSV file for the same parameters, I get four digit precision after decimal.n -
August 11, 2020 at 7:43 am
DrAmine
Ansys EmployeeHow are you writing the files? Generally, the monitor points are writing to the maximum precision level to the file.n -
August 11, 2020 at 9:06 am
Ishan
SubscriberI am writing files using following console command:nplot plot y pressure y n n pressure y 1 0 wall_1 wall_2 ()n'pressure_file' is the name of the file and its storing pressure data on two walls viz. wall_1 and wall_2. This command is written under calculation activities, so it is executed at end of each time step.n -
August 12, 2020 at 3:56 pm
Forum ModeratorAre you exporting from the xy plots? Check the axis settings (via the GUI as it's easier) to see what's set, if anything. n
- The topic ‘Increase precision in writing data from fluent’ is closed to new replies.
Ansys Innovation Space
1188
1076
1063
952
