TAGGED: 3DFDTD, database, eigenmode, FDE, material-database, refractive-index
December 10, 2024 at 12:27 am
adevata
SubscriberHello,
I have created a Sellmeier model for a material I am simulating. My model parameters follow this equation on Lumerical's documentation. This equation also closely matches Wikipedia's equation under the assumption of long wavelength. Using these equations, I've verified by hand that the model parameters (picture below) I've entered into my Sellmeier material give me the refractive index I desire (n~2.13).
However, when I run my FDE simulation, the index profile shows me a waveguide with an index of n~1.6. I'm not sure where this is coming from. When I go to the materials database and materials explorer, this value is also n~1.6. I've already made sure to switch from epsilon to n in the materials explorer when plotting the data. What's further confusing is that 1.6^2 = 2.56 =/= 2.13, so it is not simply a confusion between the materials database model accepting parameters for epsilon (~n^2) as opposed to parameters for n.
Are there any recommendations on what else I should check to ensure that my waveguide refractive index is correctly modeled via my Sellmeier parameters? Using the Sellmeier model is important since the dispersion model is crucial for the simulations I am running. Please let me know if any additional information is required from my end. Thank you for your time and help!
Best regards,AD
Relevant Photos:
- The red material here is my Sellmeier material.
- The teal material is an object defined dielectric with n=2.1344.
- The sea blue material below the teal one is also an object defined dielectric with n=1.486.
- When I replaced the red material with my teal one (n=2.1344), I have observed my desired TE mode. Therefore, I know my FDE simulation works as expected.
- These are the parameters that I have set up into the materials database. The relevant one for this FDE simulation is the zz direction, I believe.
- The anisotropy is important for my material, especially when I transfer these simulations to FDTD.
- These are the results from my FDE simulation. With 20 trial modes, a signle mode was found with an effective index of 1.66.
December 10, 2024 at 7:30 pm
Kirill
Forum ModeratorDear Subscriber,
The topic has been marked as 'answered.' Does this indicate that the issue has been resolved?
If not, could you please attach a screenshot of the refractive index vs. wavelength graph for your material, as obtained from the Material Explorer?Thank you,
Kirill -
December 10, 2024 at 7:34 pm
adevata
SubscriberHi Kirill,
Apologies for the confusion, I was able to resolve the issue myself. I realized there were unit conversion issues I was facing on my end that I had completley overlooked. I was looking for a way to delete the post, but couldn't seem to find that option anywhere. Is it possible to remove this post? Thank you!
Best,AD
December 10, 2024 at 8:19 pm
Kirill
Forum ModeratorNo problem. I'm glad to hear you have resolved the issue.
I don't believe there's a straightforward way to remove the post, but I will mark it as 'closed.'
- The topic ‘Incorrect Refractive Indices from Sellmeier Model in FDE’ is closed to new replies.
5809
