Electronics
Electronics
Incorrect net error in Q3D
    • keshar
      Hello, I am trying to simulate my PCB to extract parasitics, I have a multi-layer board, connecting one copper plane ( box of copper) to the other by Via(cylinder of copper with a hole), and I design them in Fusion 360.nWhile verifying, I get the error Incorrect nets, the net should contain a complete connected conductor. Since my layers and via are of copper and are touched to each other, I assumed they are the connected conductors. Is there any way that I can assign those as a connected conductor?n
    • CB
      Your board is a variant to our Q3D Example problem. If you need to add objects to an net just select that onject in the 3D Modeler window then go to the specific Net in the Projevt Manager window, EMC and select Add to Assignment.nn
    • keshar
      Thank you for your comment. Actually, i found option Setting> validation> skip intersections check. n
  • The topic ‘Incorrect net error in Q3D’ is closed to new replies.
