3D Design
3D Design
Incorrect dimensioning parts worksheet 2025
    • paul pladet
      A customer experienced issues regarding dimensioning while opening files in 2025. Some have moved and other dimensions have selected incorrect edges.
      Made and opened in 2024 (everything is correct):
      Opened in 2025 (dimensions have been moved and incorrect dimension values):
      As you can see SpaceClaim 2025 selects the incorrect side of a small fillet, causing the dimension to change 0,02.
      Can this be solved?
    • paul pladet
      Can someone respond to this question?
