November 13, 2025 at 9:03 am
paul pladet
SubscriberHello,
A customer experienced issues regarding dimensioning while opening files in 2025. Some have moved and other dimensions have selected incorrect edges.
Made and opened in 2024 (everything is correct):
Opened in 2025 (dimensions have been moved and incorrect dimension values):
As you can see SpaceClaim 2025 selects the incorrect side of a small fillet, causing the dimension to change 0,02.
Can this be solved?
November 17, 2025 at 11:51 am
paul pladet
SubscriberCan someone respond to this question?
November 20, 2025 at 11:26 am
paul pladet
SubscriberAnyone who can help me with this?
November 25, 2025 at 3:57 am
Devendra Badgujar
Forum ModeratorHello Paul,Â
For the drawing format issue, this is added in known issues and limitations:
DevendraÂ
November 25, 2025 at 7:58 am
paul pladet
SubscriberIs this an issue that will be fixed in a newer version?
