February 8, 2021 at 8:17 am
uirgochen
SubscriberHi,
I'm simulating an ironless linear motor in 3D model,
I found current flow from one coil to neighboring coil via contacted face,
It's not correct in realistic operation.
Even I set a little gap between them, it still happened.
The current flow should be restricted inside coil solid.
How to fix it? To avoid current flowing via the contacted face?
Thanks,
Vincent
February 8, 2021 at 4:55 pmicellb1
Ansys EmployeeHi, nYou may try assigning an insulating boundary to the coils. Select the coil, right mouse click-->assign boundary-->insulating.nFebruary 9, 2021 at 8:11 amViewing 2 reply threads- The topic ‘Incorrect current conduction in 3D simulation’ is closed to new replies.
5069
1771
1387
1248
