January 22, 2024 at 11:29 am
January 24, 2024 at 9:59 pm
HDLI
Ansys EmployeeHello Abdur,
    Could you find free eccentricity tool in ACT of Ansys store? then you could use this tool to build Maxwell transient model with eccentricity (shaft displacement).
HDLIÂ
January 25, 2024 at 11:14 am
z5344950
SubscriberHi HDLI, thanks for the suggestion. However, I was looking for a way to incorporate the experimentally measured shaft displacement (arising from unbalanced magnetic pull) into my maxwell transient model. For example, in ansys mechanical, one can define force at different time instant. Similarly, is there any way to define shaft position or displacement with respect to time in maxwell transient analysis?
January 25, 2024 at 2:12 pm
HDLI
    What is your motor type? Is it PM motor?
HDLI
January 25, 2024 at 10:51 pm
z5344950
SubscriberHi HDLI, yes it is a V type IPMSM motor, rated speed 1300 rpm, max speed 6000 rpm, rated power 1kW. 12 slot 10 pole FSCW IPMSM.Â
January 26, 2024 at 1:29 pm
HDLI
    If it is the PM motor, you can use magnetostatic solver and parameter/torque, to do parameter analysis for rotor center position and current to match your experimentally measured shaft displacement.Â
HDLIÂ
- The topic ‘Incorporate shaft displacement in Maxwell’ is closed to new replies.
5719
