3D Design
3D Design
Inconsistent Script
    • Lumbdi
      I'm generating a geometry using a script in spaceclaim. It used to work in other projects, but since I  swapped from 24R2 to 25R1 it's inconsistent and only works sometimes.
      It makes a 2D plane
      sectionPlane = Plane.PlaneXY
      result = ViewHelper.SetSketchPlane(sectionPlane, None)
      and adds lines
      result = SketchLine.Create(start, end)
      I then want to make named selections, but these lines get sometimes added to FFF/Sketching Plane1 / Sketch1 and sometimes to FFF / Surface (which is how it used to work).
      If i delete the sketchContainer1, i get an alternating once it works and then it doesn't behaviour
      selection = SketchContainer1
      Delete.Execute(selection)
      How do i make this consistent?
    • NickFL
      Based upon what you have said, my first instinct is to say that your sketch is not completely closed, or you have some inconsistent constraints. Do you have some geometry already created when this part of your script is executed?
      When you finish drawing your sketch and go to 3D Solid Mode, SpaceClaim will automatically try and fill. But if it does not do the fill automatically, you can force it to yourself. Use the commands:
      sel = Selection.Create(GetRootPart.DatumPlanes[-1].Curves[:])
      sel2 = Selection.Empty()
      options = FillOptions()
      result = Fill.Execute(sel,sel2,options)
      The part you may want to look at here is the fill options. The default GapDistance is 0.0001 [m]. Depending on your situation this may not be sufficiently large. You could increase it to something more appropriate for this sketch.
      Another thing, it is good to create a plane and then work off this plane instead of working in 3D Sketch containers. An example code would look like:
      # Bezugsebene erstellen
      selection = Selection.Create(GetRootPart().CoordinateSystems[0].Axes[0])
      result = DatumPlaneCreator.Create(selection, False, None)
      selection = Selection.Create(result.CreatedPlanes)
      result = ViewHelper.SetSketchPlane(selection)
      # Set 3 Points and create lines
      point1 = Point2D.Create(MM(9), MM(8))
      point2 = Point2D.Create(MM(13), MM(17))
      point3 = Point2D.Create(MM(25), MM(15))
      result = SketchLine.Create(point1, point2)
      result = SketchLine.Create(point2, point3)
      result = SketchLine.Create(point3,point1)
      # Grab all the lines and fill
      sel = Selection.Create(GetRootPart().DatumPlanes[-1].Curves[:])
      • Lumbdi
        I have a loop in the beginning that deletes old geometries:
        while GetRootPart().Components.Count > 0:
            GetRootPart().Components[0].Delete()
        while GetRootPart().Bodies.Count > 0:
            GetRootPart().Bodies[0].Delete()
        while GetRootPart().Curves.Count > 0:
            GetRootPart().Curves[0].Delete()
        Is there a better way to clear current geometries?
        This also doesn't work anymore, since this lines are not in GetRootPart().Components. But even if I delete everything in FFF*, this occures.
        If I include your
        at the start and:
        at the end, the first run goes through, but the second one throws an error:
        The Fill command must include a Face or Edge selection
        Which to me sounds like the same issue and GetRootPart() doesn't contain the drawn lines.
        Thank you very much your help!
        • NickFL
          Instead of the 3 while loops to delete everything, try the ClearAll().
          You are also using Workbench based upon the FFF nomenclature. I am not sure what is "saved" in the background with Workbench as I avoid it if at all possible. Can you try running in Standalone?
        • Lumbdi
          so if anyone ever has a similar problem for some reason - ClearAll() made everything stable - in that it stopped working alltogether - now the communication with the mesher stopped working as well...
          So long story short - I have absoluetely no clue why it worked sometimes, but It is now stable after swapping to solid interaction mode in the end.
          mode = InteractionMode.Solid
          result = ViewHelper.SetViewMode(mode, None)
          Lines are now not  created  in GetRootPart().Components anymore but in GetRootPart().DatumPlanes[0] - or GetRootPart().Bodies[0].Edges after switching View mode - why does that have an influence?
    • Lumbdi
      -> Reply
