3D Design
3D Design
Incomplete unfolding of sheet metal
    • Charudatta Bandgar
      Hello sui sui 我正在和团队论这个问题, 我会回到你, 因为我更了解它的原因。   English translation: I am discussing this with the team, I will get back to you as I understand more the cause of it.
    • sui sui
      Thank you very much
      尊敬的各位领导  sui sui 请看所附视频,我可以用测试.scdoc来做,但不能用设计2.scdoc,我还在试图了解原因是什么。 请遵循以下步骤。 1. 复制并粘贴金属板几何图形的外表面。 2.选择生成的表面并给出一个内部厚度。 3.选择新创建的几何体并将其转换为金属板。 4.选择面并点击展开工具。 监管。 _______________________________________________ English translation: Hello sui sui Please check the attached video, I was able to do with 測試.scdoc but not with 设计2.scdoc, I am still trying to understand what could the cause be. Steps to follow: 1. Copy and paste the outer surfaces of the sheet metal geometry.. 2. select the generated surface and give a inner thickness. 3. select the newly created geometry and convert it into sheet metal. 4. select the face and click the unfold tool. Regards.
      ? This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • sui sui
      非常感谢您的礼物,我期待着后续版本,我的愿望将实现,谢谢!
  • The topic ‘Incomplete unfolding of sheet metal’ is closed to new replies.
