November 3, 2024 at 3:54 pm
jogel23
SubscriberHi all,
I am doing a parametric analysis for different speeds of a motor from 2000 to 3000 rpm. The simulation is completed without any issues, but when I export the harmonic forces as shown in the figure below not all the forces corresponding to the different speeds are contained in the exported file. So when I import the file in ansys mechanical, I can only see the data for 4 speeds are included. How can I solve this?
Table with the different speeds
Export harmonic force options
Speeds that are actually imported in ansys mechanical
I attach the file with the harmonic force data that is generated and imported in ansys mechanical.https://drive.google.com/file/d/1T9nkCxn_bDbrPYECqL6WWquBuiRPlolL/view?usp=sharing
November 19, 2024 at 4:57 pm
Tamami Yamanaka
Ansys EmployeeHello,
Check the analysis settings to confirm that each load step corresponds to the different speeds you're interested in and that the frequency range is correctly defined for each step.
Maxwell Help > Maxwell Coupling > Maxwell Harmonic Force Coupling > Maxwell One-Way Coupling with Ansys Mechanical:
Ansys Maxwell 2024 R2 - Maxwell One-way Coupling with Ansys MechanicalMaxwell Help > Maxwell Coupling > Maxwell Multiple RPM Harmonic Force Coupling > Harmonic Force Coupling for Inverter-Fed Motors:
Ansys Maxwell 2024 R2 - Harmonic Force Coupling for Inverter-Fed Motors
6254
