May 9, 2021 at 7:00 pm
Nithinjo
SubscriberHow to set the angle of incidence for the em wave from a waveport in HFSS?
May 11, 2021 at 11:19 amVivekKamble
The angle of incidence is not available with Wave port, If you want to assign angle of incident, you can use Incident wave as an excitation.
Please go through the HFSS Excitations -> Incident wave section in the HFSS help document for more details or you can refer to online documentation here-
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/Electronics/v211/en/Subsystems/HFSS/HFSS.htm%23HFSS/IncidentWaves.htm
Regards Vivek
May 11, 2021 at 4:59 pmNithinjo
SubscriberThanks vivekk for the response.
If i use Incident wave as an excitation , will i be able to calculate S parameters??
May 14, 2021 at 12:49 amAndyJP
Subscriber>The angle of incidence is not available with Wave port
The Floquet port is an infinitely periodic wave port, which supports angle of incidence.
(there is a delay setup for the slave Floquet port in every UV direction. However, I do not remember, does it create an oblique wavefront, or just a virtual delay when postprocessing the cell into of virtually infinite array)
Viewing 3 reply threads- The topic ‘Incidence angle from Waveport’ is closed to new replies.
3827
1389
1188
1100
1015
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
