In Fluent setting inlet boundary, what are Total Gauge Pressure & Supersonic/Initial Gauge Pressure?
    • Jason Sum
      My project aims to simulate pumping pressurized air into the U shape pipe, to pump away the water remaining inside the pipe.nSay now I want to set the inlet gauge pressure of gas being pumped in to be 20 psi nIf I want the inlet gas pressure initially reached 20 psi and keep 20 psi constantly pumped, should I set both Total Gauge Pressure & Supersonic/Initial Gauge Pressure to be 20 psi?nOtherwise, if I want the inlet gas pressure increase from 0 gauge pressure to 20 psi, should I set Supersonic/Initial Gauge Pressure to be 0 psi and set Total Gauge Pressure to be 20 psi? nThanks for helping me!n
      The supersonic part only matters if the flow is supersonic, is it? n
    • Jason Sum
      I am not sure the flow is supersonic in the inlet, should I input a value close to that of Total Gauge Pressure into Supersonic/Initial Gauge Pressure ? nI found online that Supersonic/Initial Gauge Pressure is predicted according to estimating the inlet velocity (incompressible) or the inlet Mach No. (compressible). If the case is super-sonic at inlet, this value must be specified. Otherwise, it'll be ignored by Fluent in subsonic case. nCan I type both Total Gauge Pressure and Supersonic/Initial Gauge Pressure with same /similar values in case I am not sure the flow is supersonic or subsonic?nThanks so much for answering!n
      You can, but it's always recommended to understand the flow field you are modelling to ensure you are using the correct models. n
  • The topic ‘In Fluent setting inlet boundary, what are Total Gauge Pressure & Supersonic/Initial Gauge Pressure?’ is closed to new replies.
