3D Design
3D Design
In Design modeler can we do extrude/revolve operation by extracting faces from imported geometry
    • yogibavge
       If yes then how?
    • Karthik Remella
      Administrator
      You will need to create a Plane on the surface you are trying to (say) extrude. After you do this, you should be able to select this plane and provide a direction vector under the 'Extrude' operation. This will enable you to perform the operation successfully.
      I hope this helps.
      Thanks.
      Karthik
    • Keyur Kanade
      yes, you can do this.
      select any face and then select extrude command.
      as Karthik mentioned, you will need to create a plane to give extrude direction or you can also use any geometry edge for extrude direction.
      Keyur
      If this helps, please mark this post as 'Is Solution' to help others.
  • The topic ‘In Design modeler can we do extrude/revolve operation by extracting faces from imported geometry’ is closed to new replies.
