TAGGED: boundary-conditions, cfd, fluid-flow, heat-transfer
May 31, 2022 at 10:58 am
pnreddy.m
SubscriberHi
I performed analysis for air and steam fluids and the pipe as solid tubes and this is conjugate heat transfer.
When i seen stream lines some stream lines not passing outlet boundary.
and in console it says some incomplete as 320 and some escaped as 38 ( attached snapshot) why this occurs .
Please explain where may be the problem?
June 24, 2022 at 9:54 am
Forum ModeratorIncomplete means that those pathlines ran out of "steps" to reach the outlet. Typically it means that they went into a reciculation zone and didn't leave, but in this case the large number could just mean you need to increase the number of steps. 5000-10000 maximum steps in a steady case is sensible, above that and you tend to use up cpu for no real benefit as the pathines are just orbiting a point somewhere.
- The topic ‘In console, it shows stream lines escaped 320 what this mean?’ is closed to new replies.
Ansys Innovation Space
1328
1163
1090
1014
