December 24, 2024 at 9:42 pm
January 8, 2025 at 10:20 am
V.P
Ansys EmployeeHi, shin7
I dont think this is a bug in 2024 R2, as the option for turning  On or Off mesh regions, is available in 2024 R2 as well. The settings remain the same as with previous versions, and also CFD-Post loads mesh regions by default.
Can you try this:
Close the CFD post first. Then rename the .cfx file in your user profile folder. You can find .cfx file inside the "C:\Users\username" folder. Rename .cfx to .cfx_backup.Â
Now you can try opening CFD Post again and see if the issue remains.
January 8, 2025 at 10:46 am
shin7
SubscriberÂ
I already tried what you said!
Mesh regions does not work in 2024R2!!!!!
Please! try test between 2024R1 and 2024R2!
You can not see mesh regions in 2024R2!Â
You can check in below address what I say!
Please check the bug in 2024R2!
January 8, 2025 at 11:19 am
V.P
Ansys EmployeeHi Shin,
I understand your concern. I check this at my end, and could not reproduce the issue in 2024 R2.
Can you tell me where you see this, in workbench or standalone?Â
January 8, 2025 at 11:30 am
January 8, 2025 at 11:54 am
V.P
Ansys EmployeeHiÂ
Thanks for sharing links, but as per forum regulations, employees are not allowed to access links, it is only for public users. Let me investigate this further.
Did you create the workbench project in the newer version?Â
January 8, 2025 at 12:05 pm
shin7
SubscriberI tested 2024R2 with service pack 4(?).
I tested 2023R1, 2023R2, 2024R1, 2024R2!
Only 2024R2 made problem!
I think This is definitely a bug.
Please fix this bug!
5929
1306
