June 8, 2018 at 2:01 pm
ItalicBike
SubscriberHi everybody,
I'm new on the forum. I use ansys 18.2. I've some question for my job.
I've to model a experimental test, in particular the FRF of an aluminium panel subject to a impulsive load (like an hammer test). So the take-away question is:
It's possible to model an impulse load without carry out a transient analysis? Could you say me which block i'have to use?
Thanks in advance.
Best Regards
June 8, 2018 at 3:32 pm
peteroznewman
SubscriberUse a Harmonic Response system block. That can either be on its own, or linked from a Modal analysis. Here is an example on a Bridge.
Select a face to be a Fixed Support and apply a unit Force at the point where the hammer would impart an impulse load. The system will treat this as a harmonic forcing function. In Analysis Settings, select the frequency range of interest and how many points to plot over that range. Request a Frequency Response output at the point where you would put the accelerometer. The output will be like an FRF.
June 11, 2018 at 9:22 am
ItalicBike
SubscriberThanks for answer peteroznewman,
it's possible to apply a damping coefficient function frequency?
June 11, 2018 at 10:22 am
June 12, 2018 at 8:08 am
ItalicBike
SubscriberThank you Peteroznewman, but i have to define frequency dependent structural damping. Does it is possible in Workbench o I need to write an APDL command?
If yes, could you help me to understand the variuos command TBDATA, TBFIELD, TB, SDAMP?
Thanks
Best Regards
June 12, 2018 at 11:21 am
peteroznewman
SubscriberIf you click on the pull down menu on the Stiffness Coefficient line where it says Direct Input, you will see you can input frequency dependent structural damping.
June 12, 2018 at 11:56 am
ItalicBike
SubscriberSorry peteroznewman, but only 1 value? I need to input 16 values. Thanks
June 12, 2018 at 2:50 pm
peteroznewman
SubscriberDamping is frequency dependent when you use Mass and Stiffness coefficients. Here is the equation that shows how the frequency is combined with the coefficient to calculate a damping ratio.
Take the table of 16 frequency and damping ratio pairs and fit the three coefficients to your data. I can help with the fitting if you don't get a good fit.
June 12, 2018 at 4:04 pm
ItalicBike
SubscriberThank you so much, very very very useful. And also thank for you patience.
June 13, 2018 at 12:46 am
peteroznewman
SubscriberYou're welcome.
- The topic ‘Impulse Harmonic Analysis’ is closed to new replies.
4803
1576
1386
1242
