November 6, 2020 at 3:30 pm
ahmedshafie
Subscribershould i maximize face quality limit ? 0.7 is better than 0.4 ?
does face quality limit refers to elements quality or orthogonal quality ?
Should i minimize collapse skewness limit ? 0.4 is better than 0.7 ?
November 9, 2020 at 6:26 amKeyur Kanade
Ansys EmployeeIt is face skewness. nPlease check help document for skewness definitions. Link already given in another post. nPlease do not reduce below 0.5. It may distort your surface mesh. nIt will collapse the faces with skewness above 0.5 nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnnNovember 13, 2020 at 3:11 amahmedshafie
Subscriberi didnt understand what face quality limit refers to ? does face quality refer to element quality ? or refer to skewness ?November 17, 2020 at 5:13 amKeyur Kanade
Ansys EmployeeFor face quality, it refers to skewness. nFace quality limit : Fluent Meshing will try to improve the faces with skewness more than given in Face Quality Limit. nNovember 21, 2020 at 3:02 amahmedshafie
SubscriberThanks alot for your generous answer nso is there a problem for minimizing face quality limit value to 0.2 ? how to check if it distort surface mesh ?ni think quality improvement collapse skewness limit should be more than 0.7 or more ? so that we can avoid bad skewness faces ? , i think it acts like upper limit value for skewness so no cell will have skewness more than that value ndoes collapsing mesh change geometry ? thats the tradeoff i thinknnNovember 23, 2020 at 4:28 amKeyur Kanade
Ansys EmployeePlease use default values for surface mesh improvement. nIf you collapse more, it wlll distort your surface mesh.November 24, 2020 at 8:16 pmahmedshafie
Subscriberthanks for your reply but can u please answer my questions ?is there a problem for minimizing face quality limit value to 0.2 ? how to check if it distort surface mesh ?ni think quality improvement collapse skewness limit should be more than 0.7 or more ? so that we can avoid bad skewness faces ? , i think it acts like upper limit value for skewness so no cell will have skewness more than that valuendoes collapsing mesh change geometry ? thats the tradeoff i thinknNovember 25, 2020 at 5:42 amKeyur Kanade
Ansys EmployeeFor running calculation it is not required to reduce face quality to 0.2. nDepending on your geometry, if you try to collapse faces till 0.2, it may distort your geometry. You can see it by displaying and inspecting geometry. nPlease improve surface mesh till 0.7 only. That means you will not have any surface mesh with skewness above 0.7. This should be good enough. nPlease see help manual for more details about these commands. nnRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnnNovember 28, 2020 at 5:59 pmahmedshafie
Subscriberthank u alot for your generous answernso what i understand is that collapse limit skewness shouldnt be less than 0.7 as it may distort geometry nbut face quality limit i think if i minimize it as possible will not cause any problem , right ?nNovember 30, 2020 at 5:40 amKeyur Kanade
Ansys EmployeeFace collpase limit should be more than 0.5. nPlease check surface mesh skewness. If it is 0.5 then it should be good enough to generate volume mesh. nPlease see help manual for more details about these commands. nnDecember 1, 2020 at 11:17 pmahmedshafie
Subscriberthanks for your answer , i just wanna make sure for face quality limit minimizing that number wont cause problem keeping face collapse limit more than 0.5 right ?nDecember 2, 2020 at 2:21 amKeyur Kanade
Ansys EmployeeWhy do you want to change default values?nIt depends on geometry and the location where these faces above 0.5 are. nPractically I do not change default values for surface mesh improvement. nCreate a small box. Create surface mesh for the same. Then use collapse command to see visually how it works. This will help you. nPlease see help manual for more details about these commands. nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnnDecember 3, 2020 at 8:46 amahmedshafie
Subscriberthanks for answer , i found better improvent leads to nViewing 12 reply threads- The topic ‘Improve Surface Mesh in fluent meshing’ is closed to new replies.
4673
1565
1386
1236
