Imprint baffles on volume bodies in ANSYS Spaceclaim Direct Modeler
    • admin
      How to imprint baffles on volume bodies in ANSYS Spaceclaim Direct Modeler?
    • Arun Kumar
      To work with baffles in ANSYS Spaceclaim Direct Modeler, Volume bodies and Surface Bodies have to be generated/moved in 2 different components at the upper level. To imprint the baffles on the volume bodies, the Share topology option has to be set to Merge between the 2 main components. Example: Design (-> Share Topology : Merge) - Component1 (-> Share Topology : Share) -> Volume Bodies - Component2 (-> Share Topology : None ) -> Surface Bodies
  • The topic ‘Imprint baffles on volume bodies in ANSYS Spaceclaim Direct Modeler’ is closed to new replies.
