October 3, 2023 at 10:11 am
Sarath Arangat Jayarajan
SubscriberWhat is the difference between imprint and share topology operation in Ansys DiscoveryÂ
October 3, 2023 at 3:12 pm
Devendra Badgujar
Forum ModeratorHello Sarath,
The Imprint tool detects coincident faces, edges, and vertices between bodies and imprints them onto the coincident face. The contact regions will be the same shape, and the resulting mesh on each face will be similar. This can be helpful when analysing stress between two parts.Â
Share topology is used for:
- For getting Conformal mesh.
- Imprinting for Contacts or Interface definition.
Please refer FAQ - Share Topology is now available in Discovery for more information.Â
DevendraÂ
- The topic ‘Imprint and share topology’ is closed to new replies.
- Add-in Error Excel
- Fileformats
- Discovery 2025r2 failed to initialize
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- racing royals
- New Computer
1494
1386
1209
