April 18, 2019 at 11:45 am
BeginerModel
SubscriberI have done some modifications to particle data, and have extracted from this a list of x,y,z coordinates that I want to import into CFD-post as points, to plot alongside my model. Is there any way to import this data? I dont want to have to input them manually as points because there are a few hundred.......
April 22, 2019 at 9:08 am
Keyur Kanade
Ansys Employeenot sure about particle data. cfd-post expert can comment here.Â
from which solver you are exporting particle data?
once you export particle data from solver, please check the format. you may try using similar format and import it in cfd-post.Â
August 14, 2020 at 8:56 pm
HMHassan
SubscriberYou can go to File>Import>Import Surface, Line or Point Data... in ANSYS CFD-PostnSelect Import As: Point Cloud and select required .csv file.n
- The topic ‘Importing x,y,z coordinates of points into CFD-Post?’ is closed to new replies.
Ansys Innovation Space
- affinity not set
1414
1231
1118
1015
