September 4, 2023 at 12:27 pm
bbcn
SubscriberHi everyone,
DoE has created the below design points:
However, I have been having trouble to get output parameter results by using DoE. Thus, I have analysed all the design points and obtained the output parameters manually. Since I have all the output data, I would like to input those output parameters into the Responce Surface Optimization again to do the optimization. Is there a way to input the output parameter data into the Response Surface Optimization so that I can evade DoE solver? Because I have all the results, all I need is that all those data to be optimized.
Thank you.
September 5, 2023 at 3:22 pm
September 6, 2023 at 2:40 am
- The topic ‘Importing WB Output Parameter Data To Design of Experiments’ is closed to new replies.
