December 6, 2018 at 2:30 am
learn13
SubscriberHello,
I have a mesh with several node merge, geometry specific ADPL commands, and other similar considerations. After opening a new Workbench window and static structural module (same geometry imported), how can I import the same mesh, ADPL commands, and solution tools from another project.
After writing an input file from the other workbench, "Read result files" seems like a likely contender for solving this, but I have so far been unsuccessful.
December 6, 2018 at 2:56 am
peteroznewman
SubscriberOpen the Workbench file with the model you want to reuse the mesh, and model, etc. then do a File, Save As and you will have a copy that you can change, which starts with everything you had.
If it's not that simple, then I don't understand what you have and what you want to do.
- The topic ‘Importing Static Strucutral Mesh + Node Merge Conditions’ is closed to new replies.
3757
1333
1168
1090
1014
