April 9, 2024 at 2:00 pm
Goda Bataviciute
SubscriberI'm having a problem when importing .sat file to Ansys Workbench. In Geometry window, all fine with the parts (5 parts: 4 beams and 1 core part). But when i open Model window - my parts get divided into smaller parts (see picture attached). Basically the beams get devided into smaller sections, not sure why. Maybe i have to import it somehow differently? or should i choose different settings in Model window?
April 10, 2024 at 11:32 am
Sampat Kumar
Ansys EmployeeHiÂ
There could be multiple reasons for this. If the geometry errors are present in the SC then try to remove them.Â
1. Try to keep all 4 beam parts in the single component and core parts in the other component in the SC then transfer them into the mechanical.Â
2. I can see there are 5 parts under the carbon component in the geometry tree, try to suppress the extra bodies in the mechanical and see if it worked for you or not.Â
Best Regards,
SampatÂ
- The topic ‘Importing .sat file to workbench’ is closed to new replies.
5734
